oldtimer
posted on 15/7/09 at 01:34 PM |
Type 9 to bellhousing question
I have 2 type 9 gearboxes and have come to fit my alloy bellhousing. One type 9, at the input end, just has the alloy oil seal housing and the
bellhousing fits up nice and snug. OK. The other type 9 - the one I want to use - has a small plate secured by3 allen bolts underneath the oil seal
housing and which interferes with the bellhousing. So, why has one type 9 got a plate there and the other not? and, if others have come accross this
what have you done? - is it OK to remove alloy from the bell housing where this plate is??
Thanks in anticipation.
BearingKits
posted on 15/7/09 at 04:25 PM |
The box with the bolt in bush is a "modified" type, commonly found on Transit, 2.8 4x4 and some 2.8 2wd versions (rare).
The term "uprated" is also used for this box as it uses a large cylindrical roller bearing at the front of the laygear instead of needles
and the bolt is shaft you can see from outside.
The original Ford bellhousing will have a cut out to clear the bolt in bush.
The modified bellhousing gasket will also be the shape you need.
www.Bearingkits.co.uk
Gearbox, Differential and Axle rebuild parts.
oldtimer
posted on 15/7/09 at 04:37 PM |
Thanks for that, I have spoken to BGH and all is sorted now and the bellhousing fitted. Thanks.
