madteg
| posted on 16/8/09 at 09:50 PM |
Bad day in garage
Had a problem with fuel being weak at top end, changed regulator still the same, changed fuel pump for cosworth one. only to find its now running way
to rich tried dataloging all morning to no avail. Only to find i had a crack in a vacuum pipe, put it wright now ok all through rev band.
Mark G
| posted on 16/8/09 at 09:54 PM |
Sounds like a good day to me. You've ended the day with the car working better than it did this morning.
Cups half full...
iscmatt
| posted on 16/8/09 at 11:08 PM |
Mark is definatly right!!!!
You had a great day, your problem is solved, though of course it is frustrating to spend money on buying parts that were not really need/not the cause
of the problem!
locoR1
| posted on 17/8/09 at 09:17 AM |
Hi Mate!
Sounds like a good day to me that means its ready for next weekend are you going?
http://www.locostbuilders.co.uk/viewthread.php?tid=117805
Check out my CB500T Cafe Racer build diary
oldtimer
| posted on 17/8/09 at 11:29 AM |
My bad days usually end in failure and frustration.
