jonesier1
| posted on 17/8/09 at 05:41 PM |
setting alpha n
been checking out my ms troubles and as said i checked my settings for what is measuring engine load as my timing is in limp mode,in the constants it
is set to alpha n but if i suck the map pipe( from 100kpa engine off) the ignition map comes down in reading,so i presume its still reading map not
tps.How do i correct this as i cant see any way other than the one box saying speed density/alpha n ?
just found it in the configurator and changed it there but still seems the same,ie timing map does'nt change when throttle is pushed(engine
off)
[Edited on 17/8/09 by jonesier1]
im in my own little world...its ok though they know me there
| posted on 17/8/09 at 06:32 PM |
Have you read this?
jonesier1
| posted on 29/8/09 at 04:25 PM |
found it,it was in the secoundry load perameters.
