Bumble
| posted on 24/8/09 at 08:12 PM |
Fuel Cicuit Layout
Planning my fuel circuit for Zetec & R6 Throttle Bodies (Fuel Injection).
Plan is:
1) Sumped ally tank
2) Low press filter / pump
3) Swirl Pot
4) High Press pump
5) High Press filter
6) Fuel Rail
7) Swirl Pot
8) Regulator
9) Return to tank
Planning to fit LP Pump / Fllter at back of car then HP Pump (Facet) & Swirl Pot in Engine Bay. Any problems with this. Would welcome
suggestions / advice and some piccies of your set up would be a major help.
Matt
PS - what LP Pumps are recommended?h
speedyxjs
| posted on 24/8/09 at 08:16 PM |
Can i ask, why are you having a swirl pot after the fuel rail?
adithorp
| posted on 24/8/09 at 08:22 PM |
I know others have done it that way but I'd say keep it simple (tin-tops do) and just go...
Sumped tank, low presure filter, high presure pump, high presure filter, fuel rail, regulator (on end of fuel rail), return pipe to tank.
adrian
http://jpsc.org.uk/forum/
Bumble
| posted on 24/8/09 at 08:39 PM |
Speedy...return to tank goes via Swirl pot....
Adrian.....are you saying Swirl pot unnecessary with sumped tank?
Matt
adithorp
| posted on 24/8/09 at 08:44 PM |
Yes. It just complicates things and adds more things to go wrong (and weight). Don't know of any mainstream manufacturer that does it that way.
I know the fuel starvation argument, but thats why you have a sumped tank. I only get fuel starvation on track when I'm almost empty.
matt_claydon
| posted on 24/8/09 at 10:32 PM |
As above, with a sumped tank you can do without a swirl pot (and even do without an LP pump if the HP pump is below the sump level).
However:
Regulator must go directly after rail, not as you have it in your post. (Most OEM installations it is actually attached to the rail).
