speedyxjs
| posted on 28/8/09 at 07:20 PM |
Yet another (hopefully final) Megasquirt Q
Well 2 actually.
1) If i managed to get hold of a Megasquirt unit thaqt was set up for another car (4 pot), how easy is it to change it to run a 6 pot?
2) If the said megasquirt unit was set up to run edis, can it still be use on a distributor system?
flak monkey
| posted on 28/8/09 at 07:26 PM |
1) very easy, change in the software only
2) also very easy. Needs a bit of work inside the unit, nothing major though. I can talk you through it if you are unsure.
Sera
http://www.motosera.com
speedyxjs
| posted on 28/8/09 at 07:27 PM |
Cool, thanks David.
Il probably take you up on that if i get it
cd.thomson
| posted on 28/8/09 at 07:45 PM |
ah, i let you have it then
Craig
