Author: Subject: Fuel line advice
speedyxjs
posted on 16/9/09 at 09:52 AM Reply With Quote
Fuel line advice
I think iv got all the electrics sorted but wont know till i get some fuel in it.
The only way i can see being able to get them to the transmission tunnel is to run the fuel line above the ECU.
speedyxjs
posted on 16/9/09 at 09:53 AM Reply With Quote
Blue line is the proposed postitioning of the fuel line Rescued attachment DSC00271.JPG
Mr Whippy
posted on 16/9/09 at 10:06 AM Reply With Quote
Looks good so long as you put a prop catcher in, chances are with that torque and a hot dry road you could easy snap one. Though I think the fuel line should be more along this stuff
I notice your airflow meter is sticking outside the car, that’s going to be a funny looking bonnet, does the air filter and intake hose fit behind the radiator easily?
[Edited on 16/9/09 by Mr Whippy]
speedyxjs
posted on 16/9/09 at 10:10 AM Reply With Quote
Sorry, what do you mean by catcher?
posted on 16/9/09 at 10:11 AM Reply With Quote
not possible to move ecu into passenger footwell?
never the best layout having fuel above electrics, not doubt why you are asking,.
Mr Whippy
posted on 16/9/09 at 10:14 AM Reply With Quote
speedyxjs
No, the battery is taking up most of the space there.
blakep82
posted on 16/9/09 at 10:17 AM Reply With Quote
one of my old BMWs had the fuel line pass above the starter motor. the fuel line once started leaking lots didn't cause any problems though. i think it will be fine
________________________
posted on 16/9/09 at 10:24 AM Reply With Quote
not possible to to fit smaller battery then? but then you still have the same problem of fule over electrics (battery).
don't you have a shelf before he scuttle for the ecu? or under the scuttle?
or fit ecu in waterproof/fuelproof box?
speedyxjs
posted on 16/9/09 at 10:34 AM Reply With Quote
That might be a good idea
posted on 16/9/09 at 10:46 AM Reply With Quote
^^^ trawl around Land Rover sites for ideas - flooding the ECU is a common occurence. I'll bet there is a locost solution too.
Tupperware LOL!!!
malins; cheap as chips
says "A range of external waterproof boxes in a self extinguishing, thermoplastic material, which is highly resistant to impact, heat, chemical and atmospheric agents. "
Ya may wanna check is petrol is one of those chemicals.
I am sure you can get metal boxes from RS.
[Edited on 16/9/09 by 02GF74]
Mr Whippy
posted on 16/9/09 at 10:58 AM Reply With Quote
James
posted on 16/9/09 at 11:21 AM Reply With Quote
Could you not get the ECU nice and safe and dry inside the scuttle?
Then run the fuel line straight down from the engine and go along the lower chassis rails and along the lower rail of the prop tunnel.
You can put the battery inside the passenger footwell, or above the passenger footwell in front of the scuttle on the 'shelf'.
HTH,
James
speedyxjs
posted on 16/9/09 at 12:01 PM Reply With Quote
This was my initial idea but there is not enough room at the bottom next to the gearbox.
GeorgeM
posted on 16/9/09 at 05:11 PM Reply With Quote
Didn't think ecu's liked getting hot. Would it not be better away from the exhaust ??
GeorgeM
matt_gsxr
posted on 25/9/09 at 09:07 AM Reply With Quote
As this is in the EFI section I am assuming fuel injection. If a 50psi fuel line fractures I don't think the fuel will fall down (unlike with carbs). It will spray everywhere with near inevitable consequences. The priority must be to keep the fuel in the hose!
Good idea to cover the ECU if you have it in the engine bay. I've seen them in water tight plastic boxes to protect them.
Just my thoughts though.
Matt
