jonesier1
| posted on 18/9/09 at 06:55 PM |
ms and fuel pump only primes
my ms2 v3 with edis was ok fuel pump wise but in trying to sort my other running problems out i took it round the block and it conked out,no
start.After checking thinks out the fuel pump only works when i key on and off,not while its cranking(priming)if i cycle the ignition several times it
tries to fire but dies.So whats gone wrong,ive read about transistors in ms going down but it primes up .
im in my own little world...its ok though they know me there
brianthemagical
| posted on 18/9/09 at 07:08 PM |
Is it getting a tach signal?
robocog
| posted on 18/9/09 at 07:11 PM |
hook up to lappy and see if MS recognises its going into "run mode" - eg look at the RPM!
If running edis I guess its wired like mine so it /could/ be the rpm input to megasquirt is dodgy/dirty/dislodged/disconnected
(if laptop is showing no rpm when cranking/stumbling would give a good clue that its lost the connection from EDIS)
Regards
Rob
jonesier1
| posted on 18/9/09 at 07:23 PM |
will check.thanks
omega0684
| posted on 18/9/09 at 07:41 PM |
ran out of fuel?
