speedyxjs
posted on 21/9/09 at 06:03 PM |
Fuel tank pressure release
Is this normally done my the fuel filler cap? I hadnt thought about it until today and id rather not encourage the leaking.
mangogrooveworkshop
posted on 21/9/09 at 06:06 PM |
On the ebay you get bike derived one way non return valves to take care of the venting £4.50 +p&p
flak monkey
posted on 21/9/09 at 06:10 PM |
Those arent suitable for fuel injection as I found out earlier in the year. You need something to let air in an out. Otherwise you build up a huge
amount of pressure in the tank and the cheap ones then leak anyway.
You need a 2 way valve.
I ordered one direct from Newton Equipment.
You need one of these:
http://www.newton-equipment.com/inline_valves.html
TPV8 is what I have. They are the best as they dont let fuel vapour escape either so you get rid of the smell of petrol in the garage too.
Sera
http://www.motosera.com
speedyxjs
posted on 21/9/09 at 06:43 PM |
So do i need to drill another hole in the tank to fit it?
[Edited on 21-9-09 by speedyxjs]
flak monkey
posted on 21/9/09 at 06:47 PM |
quote: Originally posted by speedyxjs
So i need to drill another hole in the tank?
Not neccescelery
I used a fitting which screws into a flexible pipe and fitted it to the filler tube. Made by revotec.
Burton power sell them, search for 'revotec self sealing'
I only had 2 connections on the tank, one feed and one return, so decided to fit the breather into the filler neck.
Works fine, no probs to date
Just to say, I just have a short length of hose connected to the breather inlet, then the other ends tube loops down under the level of the back of
the car
[Edited on 21/9/09 by flak monkey]
Sera
prawnabie
posted on 21/9/09 at 07:24 PM |
I drilled a couple of holes under the handle on my alloy fuel cap lol
