Paul (Notts)
posted on 28/9/09 at 06:30 PM |
cleaning and storeing injectors
Whats the best way to store injectors now I have removed them from the manifold?
When I come to use them again whats the best way to check them and get them cleaned.?
Paul
big-vee-twin
posted on 28/9/09 at 06:38 PM |
Don't clean them until you need them again
see link
http://www.triangleltd.com
turbodisplay
posted on 28/9/09 at 06:46 PM |
I got my injectors flow tested by a guy on ebay offering a cleaning service. Fast turn arround, found that the injectors flowed 420cc, not 586 as i
was told when I bought them. Although in a v6 that is enough for more than 500hp so not an issue!
Darren
posted on 28/9/09 at 10:15 PM |
I'd be tempted to squirt some injector cleaner stuff on them and then leave 'em in a freezer bag until you need them.... then consider
getting them cleaned. It depends on how certain you are the rest of your engine is okay. With a homebrew set-up (with lots of other things that could
go wrong) a sticky injector would be a PITA and possible cause a confusing problem that might make you suspect the rest of the rig.... If you're
poppping them in a known good set-up obviously this isn't a problem and you can try running them and if you get problems get them ultrasonically
cleaned....
ashg
posted on 28/9/09 at 11:25 PM |
i stored mine in those little coin bags you et from the bank. the only way to clean them properly is in one of those utra sonic bath thingeys.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
