speedyxjs
posted on 30/9/09 at 03:10 PM |
Pressure release filler cap?
I was playing with the cooling system yesterday and got thinking, can you get a pressure release filler cap for the fuel tank like you do with the
coolant resevior?
This would save me needing to play with extra fuel lines
Staple balls
posted on 30/9/09 at 03:15 PM |
Aren't most caps vented anyway?
adithorp
posted on 30/9/09 at 03:20 PM |
Why would you want your fuel tank to be pressurised?
http://jpsc.org.uk/forum/
speedyxjs
posted on 30/9/09 at 03:29 PM |
You dont. Thats why you need a way for the vapours to get out/air to get back in.
l0rd
posted on 30/9/09 at 03:31 PM |
Isn't this why you have those one way valves?
blakep82
posted on 30/9/09 at 03:51 PM |
yeah, but i see what he's saying, it would be nice if that was built into the cap, rather than having seperate tank connections, valves and
pipes
________________________
speedyxjs
posted on 30/9/09 at 03:56 PM |
Just found this that says it is vented. Any good?
adithorp
posted on 30/9/09 at 04:06 PM |
But you were comparing it to a radiator presure cap, that holds presure up to a set level (say 15psi) and then releases anything over that giving a
presurised system.
With a fuel tank you want a vented system, so you need either a vented cap (prone to leaking) or a breather system.
speedyxjs
posted on 30/9/09 at 04:08 PM |
presurised system.
How could a vented cap leak?
adithorp
posted on 30/9/09 at 06:34 PM |
Vented caps basically just have a small hole to let gas in/out; no valve.
Fill the tank close to the top on a hot day. Fuel comes out of the underground tank at 15'c and then warms up and expands and out it'll
come. Or just corner hard with a full tank and a filler thats not far above the tank and you'll find out why early Metro's were recalled
for new caps after the Police crashed a few (fuel leaked onto the o/s rear wheel). Whereas with a breather with 2 way valve it'll seal.
speedyxjs
posted on 30/9/09 at 06:59 PM |
^^^ Thanks
