FFTS
posted on 1/10/09 at 10:44 AM |
Bike engine number needed.
Anyone with contacts in the bike breaking business may be able to help.
Just found out that the engine in my unfinished bec has a stolen recovered engine with no number on it and no paperwork.
Its a Suzuki GSXR1100 water cooled and so am looking for anyone whos breaking/broken/blown one and has a number or paperwork or both. The engine
obviously needs to be pre cat.
[Edited on 1/10/09 by FFTS]
Chris.
matt_gsxr
posted on 1/10/09 at 07:26 PM |
When I was chasing details around before I bought my engine I contacted Suzuki to see whether they could date an engine from the engine number. It
appears that they can't although if you have the frame number then they can get to the engine number.
Basically their computer only goes one way. So you need the frame number to get a date of manufacture.
I can't help with the engine thing (although I have a few littered around), although Cloudy may be able to (as he had a GSXR1100 and I think has
changed it to something R1 ish).
The other option would be to get the RF900 engine that rf900rush still has. These are spatially the same as the GSXR1100 so that the exhaust and
sprocket adapter should be the same. Also the wiring is basically the same. He didn't want much for it, and you could re-sell it.
Here was the link http://www.locostbuilders.co.uk/viewthread.php?tid=120518
Good luck, for what its worth my GSXR1100 is working nicely, and it seems to work well in a lightweight car.
Matt
cloudy
posted on 1/10/09 at 07:33 PM |
Suzuki UK in MK were able to send me a headed letter confirming the dates of manufacture for my engine, based on the engine code and model it took
some persuasion though! matt is right, their records don't work well in reverse...
I'm not yet sure what's happening to my block - so can't help on the number front. It should begin U707 or U708 for a 93 WP
James
www.warnercars.com
cloudy
posted on 1/10/09 at 07:35 PM |
PS. the gsxr 1100 is pretty solid mechanically in a BEC, never any clutch problems and bags of power - I just decided I wanted something more modern
and injected...
James
www.warnercars.com
matt_gsxr
posted on 2/10/09 at 08:12 AM |
I'm with James on this.
That is why I injected mine, and am modernizing its head.
FI is Megasquirt. And mine is going to be refreshed over the winter with an Ex-F1 sidecar head and some new cams (later cams WS/WT give a bit more
power than the WP ones), although I have some Kent Cams which seem to be quite aggressive.
At the moment I can't decide whether to do the big bore thing at the same time. All the bits are cheap because people have moved on to newer
stuff.
Mine is a U707
U709 are definitely post the emissions cut-off.
I'm not changing it because it is in anyway lacking. It is a monster. But I like the tinkering.
I have some random trivial on my WWW that may be useful. And I have loads of bits kicking around.
Matt
ban1216
posted on 2/10/09 at 04:42 PM |
paperwork
I can get a logbook for one off these from a breaker friend of mine but it is a european one and unfortunately the euro models dont have engine
numbers on the docs
so probably not much help
