posted on 4/10/09 at 08:05 PM |
FS: Testing..
Shortly I will be selling my carb setup. Probably after the last All Ford show on the 25th October.
I will be replacing my ZX9R carbs, pump, inlet, and Megajolt so they will be for sale to fund said change.
The inlet will fit a zetec, 1.8, 2.0, silver or blacktop and the holes have been slotted to suit a ST170 head.
Pump is the matching one from the bike so no overfuelling issues.
Carb is jetted as a 1.8 with 2L cams that were set up by Dave at Bogg Brothers and gave 155bhp on their rollers. Comes with the TPS, plug and short
bit of wiring.
£220 posted.
omega0684
posted on 4/10/09 at 08:12 PM |
bargain basement job that is!
is the megajolt included as well?
austin man
posted on 4/10/09 at 08:46 PM |
Ill take them as and when your ready
u2u sent
Charlie_Zetec
posted on 4/10/09 at 10:40 PM |
O/T
I know it's a bit off topic and somewhat cheeky, but what map are you using on your M/J?
I'm running the same setup as you, albeit not on the road yet.
Cheers!
posted on 5/10/09 at 11:28 AM |
Here's the map I'm using atm.
The bins go up to 7000rpm for my ST engine and the rev limit is high too. Aux uotput set for my VVT.
Just been messing with the idle advance to see what difference I get so I would recommend knocking it back to 10 deg's.
No idea if its any good but works well in mine.
ban1216
posted on 5/10/09 at 12:40 PM |
megajolt
How much would you want for the megajolt on its own i need one with tps as the one i have is using a map sensor
cheers from roy
posted on 5/10/09 at 12:41 PM |
cheers from roy
Sorry mate, all promised to Austin Man atm.
ban1216
posted on 6/10/09 at 10:17 PM |
Fair enough second dibs if it falls through??
