t16turbotone
posted on 15/10/09 at 05:35 PM |
EDIS timing light?
hi, do i need some fancy timing light to check my edis ignition timing? I have some doubts to wether the timing is being altered by Megasquirt, anyone
help pls?
tony
theconrodkid
posted on 15/10/09 at 05:40 PM |
any one will do,remember it has wasted spark tho and if a rev counter is fitted it will show 2X revs unless you set it to 8 cylinders
who cares who wins
pass the pork pies
posted on 15/10/09 at 06:31 PM |
If you've got the sort of timing light that clips over the plug lead (inductive type) then you may find that you get a rubbish or unreliable
flash when clipped onto plug lead 1 - the easy answer is to either clip onto lead 4, or to turn the clip over.
I thought my Megajolt / EDIS was knackered until I worked that one out...
turbodisplay
posted on 15/10/09 at 06:47 PM |
I used a gunson from halford timing light.
Worked perfectly on an edis 6 setup.
Because of wasted spark remember that you will get 2 flashes, so once per rpm (might limit top rpm capabilities).
Darren
omega0684
posted on 15/10/09 at 06:53 PM |
im sorry but your wrong there, connected mine up to pin 2 i think and my rev counter reads the right revs. just connected the wire labelled electronic
input on the rev counter
posted on 15/10/09 at 07:11 PM |
I think the conrodkid means if the strobe has a built in tachometer then it will read 2x the RPM which is quite correct.
theconrodkid
posted on 15/10/09 at 07:37 PM |
mine reads from the ht lead,no need to attach to any other wires
who cares who wins
pass the pork pies
charliems7
posted on 15/10/09 at 10:33 PM |
were does the light get its power?
battery's?
ashg
posted on 15/10/09 at 11:01 PM |
car battery
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
ban1216
posted on 16/10/09 at 06:33 AM |
just plug your laptop in and run the car with the software open and you will be able to see the ignition map change on screen if it is working
correctly
