omega0684
| posted on 23/10/09 at 09:56 AM |
Swirl pots?
anyone know anywhere that sells swirl pots at cheap prices? i have checked the usual culprets but they all seem rather expensive.
also what sort of capacity should i be looking at for a pinto running R6 ITB's
cheers
oh, also, are fuel clips ok for high pressure fuel systems or is it safer to change to a threaded joining system (like goodridge) etc
[Edited on 23/10/09 by omega0684]
turbodisplay
| posted on 23/10/09 at 09:59 AM |
Someone on here showed a picture of an fse swirl pot/ filter combo.
Looked remarkably similar to either a hydraulic or pneumatic filter unit, could be a possibility?
Darren
speedyxjs
| posted on 23/10/09 at 10:22 AM |
Most people use juilee clips for normal high pressure systems. I have
martyn_16v
| posted on 23/10/09 at 10:25 AM |
quote: Originally posted by omega0684
oh, also, are jubalee clips ok for high pressure fuel systems
Jubilee clips are less than ideal but many many cars get away with them. You're much better off using proper hose clips like in the pic though,
they won't pinch the hose.
martyn_16v
| posted on 23/10/09 at 10:26 AM |
IVA tester will more than likely tell you to change them for proper hose clips.
turbodisplay
| posted on 23/10/09 at 10:32 AM |
I`ve used hose clips, but not for the low pressure side, tank to first pump. Is that okay?
Darren
