FrankP
| posted on 31/10/09 at 12:00 PM |
Fuel Injection Pressure Query
My fuel pump seems to prime - when I turn the ignition on it whirrs for a few seconds. But i do not see any fuel in the return line. Does it need to
be primed?
There is a gallon in the tank!
Do I suspect that the fuel pump
What other tests can I do?
Frank
| posted on 31/10/09 at 12:03 PM |
What setup are you running?
Low pressure pump to swirl pot with seperate high pressure pump? What EFI?
tomgregory2000
| posted on 31/10/09 at 12:08 PM |
have you got your fuel lines the correct way round?
FrankP
| posted on 31/10/09 at 12:37 PM |
EFI set up
I have a swirl pot in the tank to a high pressure fuel pump.
I have checked the fuel lines are around the correct way round
Frank
Project7
| posted on 31/10/09 at 12:58 PM |
Stuck/Faulty Fuel Pressure Regulator?
Measure the fuel pressure at the rail?
Is the fuel pump below the outlet on the tank, I know the bosch ones really need a gravity feed.
[Edited on 31/10/09 by Project7]
