Author: Subject: Engine cutting out.
Staple balls
posted on 21/11/09 at 01:28 PM Reply With Quote
Engine cutting out.
my engine appears to cut out when I touch the throttle, seems to be an issue with the TPS, as it runs fine if i unplug the TPS.
using omex 500
Ideas?
cheers
posted on 21/11/09 at 01:32 PM Reply With Quote
Could even be something as simple as a worn-out TPS.... The wiper tracks get worn it the wiper is at one particular position for a long period of time...
Staple balls
posted on 21/11/09 at 02:25 PM Reply With Quote
I did wonder about that, the tps seems to work in a reasonably linear way, though one of the doodahs seems to start at 1.something k ohm, rather than 0
Edit apparently the forum doesn't like symbols, how annoying.
[Edited on 21/11/09 by Staple balls]
austin man
posted on 21/11/09 at 03:43 PM Reply With Quote
Have you tried recalibrating it through the ECU the settinggs can changes if the tps has been moves. Worth a try before bying a new one
Staple balls
posted on 21/11/09 at 03:45 PM Reply With Quote
Yep, tried that, set it up as per the manual and no change, TPS does appear to be working though, no dead spots in the ECU.
I'm thinking/hoping it's possibly a wiring oddity somewhere, but the battery died before I got chance to test stuff.
loggyboy
posted on 21/11/09 at 04:29 PM Reply With Quote
Does it have an idle control valve or simiar?
Staple balls
posted on 22/11/09 at 02:19 PM Reply With Quote
More playing, still idles fine, stalls when I hit the noisy pedal even if the TPS is unplugged.
Staple balls
posted on 22/11/09 at 02:55 PM Reply With Quote
Hmm, Seems like it's getting starved of fuel, no idea why.
