speedyxjs
| posted on 24/11/09 at 08:31 AM |
Bending straight fuel hose
I was on the lookout for some 45mm id fuel hose and i found some the other day on fleabay and it arrived yesterday only for me to realise it wasnt
properly flexible.
Is there any way to bend it and make it keep its shape? Maybe with some heat?
| posted on 24/11/09 at 08:36 AM |
depends on what it is made of.
if plastic, then put into pot of boiling water and shape. doubt that would work since you probably have rubber hose with cloth reinforcement.
you can buy hose formers - a spiral of wire with a metal strip running along the length that you put over the hose and then bend. the strip keeps the
shape and the wire kinda stops it collapsing.
there is anther type thay you put inside the tube that works in same way to stop collapsementation.
ideally, you should look for a length of hose the correct shape or use two pieces and an alloy joiner.
Davey D
45mm i.d fuel hose? what engine needs that much fueling
| posted on 24/11/09 at 08:43 AM |
I thought that too ..... but it is probably the tank filler unless he is making one of
[Edited on 24/11/09 by 02GF74]
speedyxjs
| posted on 24/11/09 at 08:44 AM |
A Jag engine lol
Naah, its for the filler.
Steve G
| posted on 24/11/09 at 09:12 AM |
Build your own Ship for £250, and cruise it??
Breaker
| posted on 24/11/09 at 09:21 AM |
A Jag engine lol
45 id fuel hose is a great idea to double the fuel capacity of your car !
stevec
| posted on 24/11/09 at 10:10 AM |
What about a coil spring down the middle of it like the thing you get in a vacuum cleaner hose? (not that I've ever seen a vacuum cleaner)
blakep82
| posted on 24/11/09 at 01:23 PM |
what shape do you need? 45 degree bend? S shape bends etc?
________________________
