scudderfish
| posted on 29/11/09 at 12:29 PM |
EDIS grounding
Do the EDIS-8 module and the coil packs assume they are bolted to an earthed component? Do either of them get hot during running and need cooling
taken into consideration? My current ideal location in my Fury would result in them being mounted on the fibreglass scuttle.
Regards,
Dave
| posted on 29/11/09 at 12:49 PM |
The EDIS module has a metal back that should be bolted to some kind of heatsink. The coil pack will be ok.
turbodisplay
| posted on 29/11/09 at 12:53 PM |
Coil is okay, it looks to me the edis module is ment to be mounted somewhere metal to disipate heat, although the amount of heat produced quite low in
normal opperating condistions.
Edit : beaten to it!
Darren
[Edited on 29/11/09 by turbodisplay]
