scudderfish
| posted on 4/12/09 at 04:56 PM |
EDIS module to sparkplug lead
If I were to make my own spark leads, what sort of plug would I need to plug into the EDIS modules?
Regards,
Dave
| posted on 4/12/09 at 05:01 PM |
Plug leads don't go to the EDIS, there's a separate coil pack that is driven by the Edis.
Any amount of places can then make you leads any length you like.
turbodisplay
| posted on 4/12/09 at 05:33 PM |
Halfords do universal leads, with adapters required to fit each setup.
If i were you use a non ford coilpack, as the ford connections are difficult to sort.
Use a coil pack with the more common type of connector (as sported by most dizzys)
Darren
| posted on 4/12/09 at 05:46 PM |
Does he really want a Supertrapp exhaust? They aren't very good in terms of flow if you make them quiet, the discs just work like variable
back pressure device. No different to inserting the DB killers (AKA HP killers) that seem to be popular at track days.
| posted on 4/12/09 at 06:11 PM |
Been drinking Mike??
scudderfish
| posted on 4/12/09 at 06:27 PM |
Sorry, I did mean the coilpacks
mcerd1
| posted on 4/12/09 at 10:40 PM |
if your using the earlier style ford coil packs then you can get the leads for an early 90's 1.3/1.6 fiesta/escort - they have normal spark pug
ends
otherwise you can get custom ones made with any ends you like
[Edited on 4/12/09 by mcerd1]
