Author: Subject: megasquirt
Stuart_B
posted on 10/12/09 at 07:34 PM Reply With Quote
megasquirt
hi all, just wondering what version megasquirt will i need to run a duratec on throttle bodies?
thanks
stuart
blakep82
posted on 10/12/09 at 07:38 PM Reply With Quote
surely any version will do it?
________________________
flak monkey
posted on 10/12/09 at 07:39 PM Reply With Quote
Any version
I am using MS1
Sera
http://www.motosera.com
Stuart_B
posted on 10/12/09 at 07:40 PM Reply With Quote
cool, i was not sure i have been reading on a few places and just getting confused.
thanks guys
stuart
dlatch
posted on 10/12/09 at 08:14 PM Reply With Quote
mtech automotive are doing a group buy on the latest V4 version might be worth a look they get good write up from the ford boys
http://passionford.com/forum/traders-parts-for-sale/311319-m-tech-v4-ecu-group-buy-1-more-definate-needed.html
big_wasa
posted on 10/12/09 at 08:47 PM Reply With Quote
You may want to do some home work before spending your hard earned with the above Not that I have ever used them.
posted on 10/12/09 at 09:58 PM Reply With Quote
Consider Microsquirt
jeffw
posted on 11/12/09 at 06:22 AM Reply With Quote
By far the cheapest option is to use a MS1 on a V3 board. If you buy it from Phil at extraEFI you can specify the various options.
I had my set-up done by Mtech and while the work got done it took longer than expect and some of the none ECU work wasn't to a very high standard. If you fit it yourself and then take the car to MTech to get it mapped you would be OK.
Stuart_B
posted on 11/12/09 at 04:33 PM Reply With Quote
hmm, thanks for all teh input will do some more resarch and no doubt ask more question on here.
cheers
stuart
