flak monkey
| posted on 9/1/10 at 07:23 PM |
Advice on setting map values in MS2
Anyone with a boosted engine able to shed some light on setting map values for the VE, AFR and Advance tables?
Max and min values are easy. What I am after some advice on is how I should spread out the bins in between. Where should I concentrate to give higher
resolution on a boosted engine?
I am expecting a relatively linear increase in boost with rpm, so around 6-7psi at 4000rpm and 15psi at redline.
So even when cruising theres going to be some level of boost so am I right in thinking that the map signal will be over 100kpa or am I still going to
see a vacuum on the valve side of the throttle plates?
Thanks,
Sera
http://www.motosera.com
t16turbotone
| posted on 10/1/10 at 08:08 AM |
what i done was to use one off phill ringwoods maps and just adapted it to suit my engine, have to say his VE maps and spark maps were pretty damn
good!!
http://www.extraefi.co.uk/downloads.htm
bottom of the page click various maps, i made my map up from the zetec turbo and rover turbo files
snapper
| posted on 10/1/10 at 08:41 AM |
Any boost that the engine/manifold sees will show as over 101.325 KPa so if you are indeed getting boost at cruise you should see it in the run data
from the map sensor.
On my Jolt running MAP, the recorded runtime data whilst a little confusing at first it gave me rev points and KPa's to look at.
Let us know what you do, looking at Squirt myself now.
I eat to survive
I drink to forget
