cd.thomson
| posted on 20/1/10 at 02:49 PM |
wtd: ignition map for 2.0L C20XE on ZX9r carbs
got my megajolt through the post from trigger-wheels today.
does anyone have an ignition map I can load on to it once ive got the engine going?
ta
presumably any ignition map for a 2l engine with bike carbs using tps is going to get me pretty close
[Edited on 20/1/10 by cd.thomson]
Craig
matt_gsxr
| posted on 20/1/10 at 02:54 PM |
not mine but this came up recently on another forum:
link
Matt
cd.thomson
| posted on 20/1/10 at 02:58 PM |
looks good matt, the X-axis says "MAP" but goes between 0-100 which suggests TPS?
Craig
matt_gsxr
| posted on 20/1/10 at 03:21 PM |
Not sure.
Best to contact him directly as he is a nice guy and its not something that you want to get wrong!
Matt
SPYDER
| posted on 22/1/10 at 05:36 PM |
Linky map looks like a MAP sensor map to me too. The 0 - 100 scale is in Kpa.
30 degrees at WOT and high revs should be a safe starting point. My 3SGE runs 34 degrees at WOT above 3000 revs.
I am posting my ignition map for your perusal. It is, again, for a MAP sensor.
Shouldn't the figures be broadly similar if the scale up the left was 0-100 TPS?
Whereabouts in Notts are you. I'm not far away.
Geoff.
[img] [/img]
