big_wasa
| posted on 9/2/10 at 08:54 PM |
Fuel inj pump question.
I have a bosch style ext pump.
Q) Will it be happy to pull fuel from a dip pipe in the top of the tank or does it need to be from the bottom ?
I may have to get another tank made as my outlet is 5mm from the panhard rod.
cheers
theconrodkid
| posted on 9/2/10 at 09:00 PM |
they dont like lifting fuel.
i had a similar prob,i made a proper sized outlet and bolted/sealed with araldite to the tank,it never leaked
who cares who wins
pass the pork pies
paulf
| posted on 9/2/10 at 09:32 PM |
Are you using a swirl pot ? or is it built into the bottom of the tank?.I have an external swirl pot fed by a facet red top this in turn feeds the
Bosch HP pump.I think most do it this way but some people put a small pot on the bottom of the tank and feed the HP pump from an outlet on this below
the tank.
Paul.
big-vee-twin
| posted on 9/2/10 at 10:11 PM |
Mine has a sump in the bottom of the tank and the pump is located at that level you must gravity feed the pump, also needs a pre filter too
http://www.triangleltd.com
| posted on 10/2/10 at 08:18 AM |
Once the fuels flowing I don't think they care (in the same way that you can put them near the tank or near the engine [as in my tintop] ). But
you might have issues with inital priming of the fuel pump if you put it up high.
Personally I'd add a take-off at the bottom of the tank (there are various options to do this including "bolt-in" jobbies that you
only need access from the outside of the tank) and use the dip tube as the return line.
Actually, I'd be tempted to try it from the dip tube and see what happens.
Things rarely do what the books and experts say and there's one way of finding out if it will work
big_wasa
| posted on 10/2/10 at 05:22 PM |
I have a lift pump, just thought I could leave this out and use the high pressure pump. But wanted to pull from a dip tube as the conections would be
away from the panhard rod.
I will go have another look at how near the outlet is to panhard rod
