adrianreeve
| posted on 10/3/10 at 09:21 PM |
A question about Ford PATS ecus
Am I right in thinking that a PATS ecu for a Ford is only any good to you if you have a matching set of keys to go with it, or can you trick an engine
into running with one of these?
big_wasa
| posted on 10/3/10 at 09:30 PM |
No you need the matching key. I have found no way around it on the ford.
Its easy to use out of the car for cars between 95 and 97 ish. There are just four wires for the antenna
Rx and Tx into the ecu
Perm live and earth.
What do you need ?
big_wasa
| posted on 10/3/10 at 09:32 PM |
If you want to do some reading its an Rdif setup.
adrianreeve
| posted on 10/3/10 at 09:40 PM |
I have one that came with my engine, and was wondering whether it was worth putting on ebay, or putting in the skip!
Adrian
big_wasa
| posted on 10/3/10 at 09:42 PM |
They can be re coded. But the job would cost more than a 96 mondeo would be worth.
Bin. Out of interest whats the name on it ?
adrianreeve
| posted on 10/3/10 at 09:46 PM |
It's a TELL unit.
Adrian
big_wasa
| posted on 10/3/10 at 09:48 PM |
thats an eec-iv 2.0 mondeo around 95
~96 then
big_wasa
| posted on 10/3/10 at 09:49 PM |
You may shift it for a couple of quid to some one to gut it for a megasquirt adapter.
adrianreeve
So is it pre PATS then?
big_wasa
| posted on 10/3/10 at 09:51 PM |
Nope its pats
but it was worth checking
Pre pats would be Desk Deep Dewy for the 2.0 manual mondeo
adrianreeve
| posted on 10/3/10 at 09:54 PM |
Ye knows too much about ecu codes!!
big_wasa
| posted on 10/3/10 at 09:56 PM |
http://www.youtube.com/watch?v=Pxq4ks2Us_U
