big_wasa
| posted on 30/3/10 at 07:52 PM |
Idle valve or not ?
Lets have some advice please.
I am running a Griffin style log manifold on a zetec with a single Throttle body.
My Ecu will run an Idle control valve or do I crack the throttle open enough to get the idle and use the advance to help. ?
Any opinions on the job
flak monkey
| posted on 30/3/10 at 07:56 PM |
I just use cold idle advance to up the speed a little bit.
You do pay with a rough cold idle, but it only lasts a few minutes. Once tuned the engine should still start on the button.
Sera
http://www.motosera.com
eddie99
| posted on 30/3/10 at 08:16 PM |
Was just about to post a similar thread, they give a bosch part number but im not sure if its worth it
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
paulf
| posted on 30/3/10 at 08:41 PM |
Theres no need for it, ive never had any idle control valve fitted and find that if I just keep it idling with the pedal for a few seconds from cold
it is able to tick over just using the warm up enrichment.
Paul.
atspeed racing
| posted on 12/4/10 at 07:12 PM |
depends on your management system.
systems like the omex feature idle spark scatter. so if you decide not to use the idle control valve/stepper motor, you can use the idle spark
scatter, which will constantly swing igntion timing back n fourth around a target idle RPM to keep the idle steady.
- colin.
