Author: Subject: Injection advice
r1_pete
posted on 2/4/10 at 09:16 AM Reply With Quote
Injection advice
I'm thinking of fuel injecting the 4.2 straight six engine in my e type.
I could use itb's or jenveys, but was thinking a bit more locost.
If I used a manifold like the one in the picture, drilled and welded injector inlets to each runner, then used two, preferably 3 if I can get a triple carb manifold, Focus / Mondeo throttle bodies, would it work / be worth it?
I know some clever stuff has been done on here with injection, so any advice welcome.
Mark Allanson
posted on 2/4/10 at 09:35 AM Reply With Quote
Couldn't you just lift the whole injection system off a XJ6 or similar, would save £££'s and hours of tribulations
r1_pete
posted on 2/4/10 at 10:16 AM Reply With Quote
Yes I thought about that, but this is the old XK engine, not sure the later straight 6 manifolds woild fit.
matt_gsxr
posted on 2/4/10 at 10:34 AM Reply With Quote
2 sets of gsxr600 TB's (maybe £60 a set) would bolt up nicely and cost a lot lot lot less than Jenveys. You'd have to respace, but that isn't difficult, and then make up a fuel rail (also easy, although the rail might cost £30).
This will look awesome.
Matt
posted on 2/4/10 at 11:01 AM Reply With Quote
Mk III version of the original JX6 had a fuel injected XK engine, I think it used the Lucas "Hotwire" system which I know can work very well. From experience of that system on Rover models I know the ECU for that system was self contained a separated from inputs from the cars electrical system, so it should be possible to transplant it and the electronic ignition.
Mark Allanson
posted on 2/4/10 at 11:34 AM Reply With Quote
Boggle could make up plates to match the manifold and the head, you would just need to weld the connecting tubes.
mark chandler
posted on 2/4/10 at 11:47 AM Reply With Quote
Late 4.2 had Lucas flappy box EFI, not an issue as you lose the flappy bit and megasquirt.
Or make up a manifold the two sets of triumph triple TB's is the way to go as they are super cheap and sized for a 900cc bike engine.
Regards Mark
matt_gsxr
posted on 3/4/10 at 08:55 AM Reply With Quote
Good thought on using triples I assume they are respaceable.
A problem with gsxr600 is that the tps is on the opposite end to the cable control. You can get a bit of wind-up through all the linkages even with 4 TB's so with 6 it would only be worse.
I guess the problem with triples is that you need some kind of splitting of the cable control.
Lots of options
Matt
