stupott901
posted on 6/4/10 at 01:24 PM |
firblade help
hi there
I hope some can help since finishing my mk 893 indyblade late last year this is the first i have managed to the car out for an decent run
the problem is when I accelerate its fine to begin with then higher up the revs the power dies of and seems to start backfire
and it seems to max out at 60 mph when the engine is cold it is worse.
has any one any ideas what the problem is?
thanks stu
jimgiblett
posted on 6/4/10 at 01:30 PM |
Have the carbs been rejetted?
- Jim
Davg
posted on 6/4/10 at 01:34 PM |
Hi Stu
plugs, coils or leads breaking down or fuel starving potentially. Have you done owt with either?
cheers D
matt_gsxr
posted on 6/4/10 at 01:38 PM |
I guess fueling. I am with Jim on this one.
What are the spark plugs looking like.
Andy Bates is your man for these engines.
Matt
stupott901
posted on 6/4/10 at 01:48 PM |
no the carbs have not been rejetted
the spark plugs and leads are new
but the previous plugs did get fouled up this is the 3rd set.
Is Andy bates a member on here or is it better to phone him at work ?
thanks for the help
jimgiblett
posted on 6/4/10 at 01:56 PM |
Andy frequents these pages now and then but probably best to give him a call. He will also be able to supply the jets.
AB Performance
I am guessing you are running foam filters and you are leaning out as the revs rise.
- Jim
[Edited on 6/4/10 by jimgiblett]
stupott901
posted on 6/4/10 at 02:01 PM |
Yes have foam filter and yes it loses power higher up the revs
is it better to use origanal airbox?
thanks
jimgiblett
posted on 6/4/10 at 02:09 PM |
In my opinion yes, but this is a contested topic.
Most of the Fireblade engined RGB race cars run Airboxes (usually one of Andy B's special designs). An airbox will reduce induction roar and
help keep you the right side of the noise police at track days. If you can fit one under the bonnet I would.
- Jim
stupott901
posted on 6/4/10 at 02:22 PM |
thanks jim for advice I wil give him a bell
cheers stu
ReMan
posted on 6/4/10 at 02:27 PM |
I second that it needs an airbox at very least and/or jetting to suit whatever filter setup you have.
Classic symptoms ![](/images//smilies/wink.gif)
Lightning
posted on 6/4/10 at 02:35 PM |
Mine old car did that. Rejetted larger main jets. Kepping the air box if you can would be the better option
[Edited on 6/4/10 by Lightning]
posted on 6/4/10 at 05:14 PM |
Has it been stood with fuel in the floats ? It could be gummed up jets and needles.
mad-butcher
posted on 6/4/10 at 05:34 PM |
I often ask myself would Honda etc have spent millions on designing an airbox if 30p worth of foam would work just as well. turn the airbox around
point the 2 trumpets into the cold air stream of the bonnet vent.
tony
Steve Hignett
posted on 6/4/10 at 05:48 PM |
Which fuel pump are you using?
stupott901
posted on 6/4/10 at 09:09 PM |
hi steve
im using an solid state facet fuel pump with 1.5 - 2.5 psi
stu
Steve Hignett
posted on 6/4/10 at 09:13 PM |
I thought you might be - they could be fine, but is there anyone at all in your area that could lend you a Blade pump?
They are self regulating, so you don't need a fuel pres reg at all after the pump, just a filter.
It doesn't have to be a blade pump, it can be similar, like a carbed R1/ZX9 etc, but I always felt Blade for Blade is best...
stupott901
posted on 6/4/10 at 09:59 PM |
hi steve
there is no one i know of with an blade pump
i have had a look on ebay but couldnt see any thing they seemed newer model pumps
stu
Steve Hignett
posted on 6/4/10 at 10:07 PM |
Just had a look myself , but nothing jumped out at me (a few R1 pump's but getting on for £50)...
Maybe put a specific Wanted post on here - someone's bound to have one. Failing that, call Andy Bates or Malc Yorkshire engines...
hicost blade
posted on 6/4/10 at 10:35 PM |
893-919 blade never had a pump.....I have a ZX6 pump for mine from AB performance, I will get the part no. tomorrow for you
hicost blade
posted on 6/4/10 at 10:49 PM |
carpmart
posted on 7/4/10 at 09:50 AM |
Any carbed bike engined fuel pump will do you. I think they are pretty much the same and made by Mitsubishi
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
stupott901
posted on 7/4/10 at 07:43 PM |
thanks guys for help well i have ordered an airbox just need to find an fuel pump then i shall see
cheers
posted on 8/4/10 at 11:45 AM |
893-919 Blades do have fuel pumps.......
Phil
stupott901
posted on 11/4/10 at 10:15 AM |
Hi there guys
i have fitted the fireblade airbox and it is running alot better now at least i can get over 60mph now and the acceleration is better, still not
perfect but its more drivable so i might take it to an local tuner with an rolling road and see what they say.
thanks for the help and advice
stu
