Author: Subject: Hose size reduction problem
scudderfish
posted on 23/4/10 at 08:26 AM Reply With Quote
The output from my idle valve is 22mm, the input to my manifold is 10mm. I have no access to a lathe. Is there anyway I can simply make some sort of adapter (plumbing supplies?) that will let me connect the two up?
Regards,
Dave
Stott
posted on 23/4/10 at 08:29 AM Reply With Quote
would this be any good?
Adaptor
You can get them in b&q etc
scudderfish
posted on 23/4/10 at 08:37 AM Reply With Quote
I love this site
Thanks for that.
Stott
posted on 23/4/10 at 08:55 AM Reply With Quote
no probs, if you buy a yorkshire one/pre- soldered it's beaded for you too
Should have linked this first - click me
posted on 23/4/10 at 09:22 AM Reply With Quote
Note the dimensions on the reducer refer to the inside diameters! The OD will obviously be a bit larger.
