scudderfish
posted on 25/4/10 at 06:09 PM |
It didn't start first time
I've been converting my RV8 from carbs to full EDIS-8 Megasquirt. It's been off the road since November and tonight was the night. It
didn't work. I'm not overly surprised though as I think the battery is somewhat flat as the ECU dropped out on cranking which my Elise
used to do if I left it for a few weeks. Oh well, I've put it on charge and I'll have another play in the week.
Paul (Notts)
posted on 25/4/10 at 06:40 PM |
Just a thought - make sure the ecu supply is connected to a Live that remains live when cranking. Just been doing some wiring on mine and almost made
the mistake of using a live supply from the ignition switch that cuts out during cranking.
Hope its starts next time
Paul
running about two weeks behind you in tring to start mine.
matt_gsxr
posted on 25/4/10 at 09:07 PM |
Exciting times.
Make sure you turn logging on then you next try.
I just swapped my engine over, but have a couple of wires to connect before seeing if it works.
Matt
MakeEverything
posted on 25/4/10 at 10:01 PM |
Happy Days Dave, look forward to seeing how it goes so that i can pick your brains!!!
Kindest Regards,
Richard.
scudderfish
posted on 26/4/10 at 10:35 AM |
I think I might have made a comedy schoolboy error. In bed last night I realised that I may have connected the +12 for the EDIS module to the feed
coming off the fuel pump relay. FPR is not energised unless MS sees the engine turning. MS won't see the engine turning until EDIS is alive.
EDIS comes alive when FPR is energised......
scudderfish
posted on 29/4/10 at 05:33 AM |
I've made an even better comedy error than the one I postulated above. The EDIS module did have a correct +12v feed, but it might help if I
gave the coil packs +12v as well instead of leaving the wires unconnected
iank
posted on 29/4/10 at 06:25 AM |
More chance of a spark once that's fixed
Anonymous
