daniel mason
| posted on 3/5/10 at 01:47 PM |
s2000 fuel level sender! will it work?
hi, i have the fuel level sender from my s2000 and was wondering if it can be used in my mnr.its just about right for depth of tank but has 2 plastic
nipples on top where the honda fuel lines were connected! can these be blanked off or used as breathers allowing me to use the inlet and outlet
currently on my ally tank?
l0rd
| posted on 3/5/10 at 02:07 PM |
I would suggest blank them off.,
probably a piece of tube running one to the other.
f20ckitcar
| posted on 5/5/10 at 10:01 PM |
I used the S2000 Fuel pump/sender integral unit, although also used the S2000 harness (albeit not much of the original left after removing the
redundant wires) and S2000 dash/clocks.
Chris
daniel mason
| posted on 6/5/10 at 05:13 PM |
thanks chris. i am using sender which i have modified to suit my ally tank but am not connecting the in-tank pump rom the sender.i will link inlet and
outlet together on top of the sender and fit new pump under tank somewhere. am also using steering,diff,clocks,prop,ignition etc
