scudderfish
| posted on 15/5/10 at 04:15 PM |
V8 EDIS MS Non start
Further down the path, but still not running. I've posted a video here
http://picasaweb.google.com/lh/photo/L9u17vskyu3gjg9dHabvhg?feat=directlink (pick the HQ option) to show what's happening.
The HP fuel pump primes, I crank the engine and the injectors inject. Sparks spark but the engine doesn't start , it tends to bog down, goes
'phut' and something blows out of the inlet manifold.
What is the most likely thing(s) I've stuffed up?
Regards,
Dave
robocog
| posted on 15/5/10 at 04:23 PM |
timing?
Definately got 12v to Megasquirt/edis/coilpack/fuel pump when in crank? (not just run)
Regards
Rob
omega0684
| posted on 15/5/10 at 04:49 PM |
might sound silly but you got enough fuel going in?
[Edited on 15/5/10 by omega0684]
Agriv8
| posted on 15/5/10 at 04:51 PM |
spark too early ? sparking while the inlet still open
Spark plugs wet ?
regards
Agriv8
| posted on 15/5/10 at 05:05 PM |
HT leads not connected to the right cylinders?
Paul (Notts)
| posted on 15/5/10 at 05:07 PM |
Can you put up a link to your MS map.
sounds like its sparking too soon.Chect the cranking settings on the MS
are you 1000% certain the VR sensor is in the correct position on the trigger wheel.
I am still a few weeks off starting mine.
Paul
scudderfish
| posted on 15/5/10 at 06:50 PM |
Thanks guys. I found I had the sides of the coils crossed (A was B, B was A, C was D D was C) which was probably the cause of sparks with the inlet
port open. I also had a small leak of petrol and managed to spray myself with petrol fixing it so I've given up for the night now I've
had a shower
Right now I suspect pretty much everything I've done. Timing may well be out as I based the trigger wheel position based on the marks on the
damper. I assume this is probably correct as it is located by a woodruff key. I'll try again tomorrow.
