Author: Subject: Injector - Manifold fitting.
r1_pete
posted on 26/5/10 at 11:15 AM Reply With Quote
I'm in the process of modifying a manifold to take modern push in injectors, its an old XJ6 manifold which had stepped injectors.
Question is,
Am I ok to bore straight through with the push fit diameter, and leave the injector body to shoulder up against the manifold,
OR
Do I need to leave a step in the bottom of the injector hole??
Cheers.
Pete.
posted on 26/5/10 at 01:56 PM Reply With Quote
Well some people just use copper t-pieces which don't have a shoulder so I think a straight bore should be okay (though if you get lots of leaks don't blame me ).
will121
posted on 26/5/10 at 05:05 PM Reply With Quote
are you refering to the injector end going into the manifold or the fuel rail? if into the manifold would think depends on what type of injectors you are using and how they seal up against manifold either at end, shoulder lip or o ring?
r1_pete
posted on 26/5/10 at 05:50 PM Reply With Quote
They're O Ring seal, I've bored the manifold to take the injectors now, a really tight push fit, needed a dab of rubber lube to get them in.
The following pics tell a better story, if I've made an arse of it, its not a great loss, but let me know what you think, next job is the fuel rail.
Injector
Injector
Injectors1
Injectors1
Injectors2
Injectors2
[Edited on 26/5/10 by r1_pete]
will121
posted on 27/5/10 at 02:53 PM Reply With Quote
i would say look fine to me, with a good seal and in far enough to suit spray pattern, are you looking for fuel rail to be utilised to secure injectors?
r1_pete
posted on 27/5/10 at 05:09 PM Reply With Quote
Yes, I've an alloy rail blank, boring that and fitting the support brackets is the next job, then need to cut and shut the manifold to get it to clear the engine frame.
