r1_pete
| posted on 3/6/10 at 05:16 PM |
DCOE Style Jenvey Info needed
Can anyone tell me the diameter of the injector fitting on the DCOE style jenveys?
snakebelly
| posted on 3/6/10 at 07:37 PM |
not without taking mine apart! Call Jenvey on 01746 768810 and ask for Simon he will either know or can find out, they are a pretty helpful bunch
SeaBass
| posted on 3/6/10 at 08:51 PM |
Don't quote me but I thought this should be 13.8mm for standard injectors.
http://extrudabody.com/TechInfo/Rail_Drilling.html
[Edited on 3/6/10 by SeaBass]
r1_pete
| posted on 4/6/10 at 08:42 AM |
Thanks Chaps, 13.8 - 14mm is good, means my injectors will fit.
| posted on 4/6/10 at 01:25 PM |
From www.jenvey.co.uk
What type of injector?
Dimensions: All Jenvey injector mountings and fuel rails will accept either the standard 'O' ring mounted injectors for 14mm bores as
supplied by Bosch, Weber, Lucas, etc (64mm between 'O' ring centres) or the shorter 'Pico' style injectors (38mm between
'O' ring centres).
There are a number of other injector types, using the same 'O' rings but with different lengths. These can be used on our twin throttle
bodies with ease, but may require different fuel rail mountings on individual bodies. Please specify which you are using when ordering throttle bodies
and fuel rails.
Flow-rate:When fitting our throttle bodies to an otherwise standard engine bear in mind that increased power means increased fuel demand and
the original equipment injectors are therefore usually inadequate.
