Author: Subject: Velocity Brake Hoses
Gareth
posted on 26/5/04 at 01:23 PM Reply With Quote
Could somebody tell me the ideal length brake hoses to use for the Velocity?
If you know if these are from a standard car (sierra, freelander etc), it would be very helpful?
Gareth
Findlay234
posted on 26/5/04 at 04:11 PM Reply With Quote
do you mean flexi or rigid? For either of them either buy the kit from luego(expensive i know but i wich id done this would have saved a lot of time) or buy a roll of the stuff and cut it to length in your chassis. With the flexis buy from raldes and you cut the length to match. if you still want a length after that then fone luego theyll be able to help, always ready to offer assistance they are.
Ferg
posted on 26/5/04 at 05:04 PM Reply With Quote
If you are after braided Aeroquip stuff try Anglia Hose & Hydraulics at Stanway. Nearly into Copford by the garden centre.
Gareth
posted on 28/5/04 at 10:48 AM Reply With Quote
Cheers for the replys
Gareth
James
posted on 28/5/04 at 10:53 AM Reply With Quote
Horsham Brakes seem to be a national supplier.
HTH,
James
andytmc
posted on 31/5/04 at 12:55 PM Reply With Quote
The Goodrich bits I got from Luego are 48cm & 64cm (not counting the fittings)
