Author: Subject: Could my DIY mapping be causing this?
t16turbotone
posted on 6/7/10 at 11:25 AM Reply With Quote
Hi folks, although ime more than hapy with the performance of my T16 engine, there is one problem that i carnt seem to get rid of. The clutch slips in 3rd gear under boost, the clutch itself is a five paddle CERAMETALLIC jobby with uprated cover, the flywheel was resurfaced when fitted and gearbox and crank seals where replaced. Ime running on Megasquirt and have mapped it myself, was just wondering if my diy mapping could be some of the problems? what do you think pls??
phoenix70
posted on 6/7/10 at 11:39 AM Reply With Quote
Can't see how your map could give you clutch slip, other than the car is producing so much torque it's defeating the clutch.
[Edited on 6/7/10 by phoenix70]
john_p_b
posted on 6/7/10 at 11:44 AM Reply With Quote
nope, not unless you are running mental amounts of torque and even then thats not a problem it's simply showing up the clutch isn't up to the job.
have you checked the simple things like clutch cable adjusted correctly etc?
built a car, built a home, had a family. lost the family, lost the home, still got the car.
flak monkey
posted on 6/7/10 at 11:54 AM Reply With Quote
Where did you get the clutch?
If its an ebay special they are notoriously crap, hence why I fitted an AP one. Yes double the price, but even with an organic plate and 245lbft it doesnt slip.
Sera
http://www.motosera.com
t16turbotone
posted on 6/7/10 at 11:56 AM Reply With Quote
Thanx guys, must admit problem does tend to point to clutch not man enough Not sure i can face gettin engine out again this year
tony
t16turbotone
posted on 6/7/10 at 11:58 AM Reply With Quote
clutch was made for me by CG motorsport.
ime a little annoyed, power and torque figures were given to them beforehand
tony
adithorp
posted on 6/7/10 at 12:28 PM Reply With Quote
Should have used a bike engine...
adrian
PS. I only say that as you were obviously considering it by posting in this (BEC)section.
pps. Then you go and move it to here...
[Edited on 6/7/10 by adithorp]
http://jpsc.org.uk/forum/
posted on 6/7/10 at 01:50 PM Reply With Quote
tony
Well I'd be wanting to have a chat with them then cos it sure ain't the mapping (unless your new map has unleashed so many ponies the current clutch can't restrain them all!
sebastiaan
posted on 6/7/10 at 02:24 PM Reply With Quote
tony
Which COULD still be the case if you get a massive boost spike by having the boostcontrolling solenoid mapped wrong. Key to finding out is doing a 3rd (or something) gear full throttle run and logging the MAP to see if it shows significant overshoot when coming on boost.
hicost
posted on 6/7/10 at 02:54 PM Reply With Quote
Paddle Clutch
Its probably the clutch, I use a 4 paddle on mine and can do a on the rev limit start with a LCD & Locker and it will not slip a bit all the way through the box, and thats around 400ftlb of torque.
If you want to get it relined with the proper material I can give you an address in Wales of a place I use as I get my same one relined evry 3500 to 5000 miles
James
"I cant do that without accidentally grabbing hold of the work of the divine potter"
omega0684
posted on 6/7/10 at 03:44 PM Reply With Quote
tony
mate we could do it in a weekend!
