Furry
| posted on 27/7/10 at 02:00 AM |
zx6r carbs running on three cylinders.
hi everyone over the weekend i noticed my car running on three cylinders. i have zx6r carbs fitted and after some investigation discovered that fuel
was coming out of the hole next to the slow pilot air jet (hole to the right onf the jet when you look into the carburettor mouth) on the four
cylinder carb. when reved this clears and it runs on four until the hole starts squirting out fuel again when it returns to 3 cylinders. i've
played with the float level to mixed effect. any suggestions greatfully recieved
Danozeman
| posted on 27/7/10 at 06:15 AM |
Dodgey float needle? Too high fuel pressure? What fuel pump have you got? Are they brass needles or rubber tipped?
Dan
ashg
| posted on 27/7/10 at 08:11 AM |
Take the top cover off. Sounds like the needle has come out of the diaphram. Had it on mine once.
[Edited on 27/7/10 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Furry
| posted on 27/7/10 at 11:03 AM |
thanks for the responses. the needle is cited in the diaghram o.k. the hole is at the bottom of the carburettor mouth just below the carb trumpet next
to the slow idle jet. i'm also running a zx6r fuel pump
Dingz
| posted on 27/7/10 at 12:45 PM |
as someone has already said sounds like a poor seating float valve take it out and check for dirt.
went on and on.
