NS Dev
| posted on 2/8/10 at 05:39 PM |
ford 6 cylinder coil pack pinouts
anybody know which plug pins on the 4 pin plug on these coil packs are which coil outputs?
big_wasa
| posted on 2/8/10 at 05:48 PM |
this thread should tell you what you need
Chippy
| posted on 2/8/10 at 10:10 PM |
Looking at the coil pack with the four pin plug towards you, and going from left to right pin 1 does the first two L/H plugs, pin 2 does the middle
two plugs and pin 3 does the two R/H plugs, pin 4 is the common supply. At least thats how mine works. HTH Ray
