Dave Bailey
| posted on 7/8/10 at 04:45 PM |
Fuel Tank Woes
Well... I thought I was going to make things easier when i decided to use a Subaru in tank fuel pump... The problem is that I have had problems
setting the fuel pressure at the rail.. It turns out that the Subaru fuel pump assy has a 'jet pump' that transfers fuel from one side of
the tank to another.. I have three fittings on the top of the tank...
1. The flow.. no issue
2. The return which connects to the jet pump
3. What I thought was a vent but in fact is the out put of the jet pump that transfers fuel.
I can remove the jet pump and just have a return into the tank but it means I have an extra tube that would vent to atmosphere when in fact I already
have a vented cap. Is there any issue with a having two vents and how is the best way to prevent fuel from coming out of the tank with a one way
valve? so that air can get in and the tank vents pressure through the cap?
Any thoughts?
thanks
Dave B
[Edited on 7/8/10 by Dave Bailey]
PSpirine
| posted on 7/8/10 at 04:59 PM |
If you've already got the venting sorted, could you not just block it off?
Either a rubber hose cap, or the locost way of fuel hose, and then plug it with a bolt (clamped of course).
Dave Bailey
| posted on 7/8/10 at 05:02 PM |
could do but I don't think it would hurt to have a one way valve in it so that i can be 100% sure that the tank does not end up with a vacuum in
it.
thanks
Dave B
interestedparty
| posted on 7/8/10 at 05:11 PM |
You can get valves for that, Merlin Motorsport do them, they let air in and out only when there is a low pressure differential, good for stopping fuel
coming out the vent pipe when cornering hard.
Here you are-
http://www.merlinmotorsport.co.uk/p14603/INLINE-BREATHER/VENT-VALVE-5/16-PUSH-ON/product_info.html
not cheap though at £40
[Edited on 7/8/10 by interestedparty]
