r1_pete
| posted on 13/8/10 at 08:02 AM |
Heat insulation material - Carbs to Manifold
Ok its not quite a fuel injection post but....
I need to make some insulators up for the temporary carb setup I'm working on, does anyone know a supplier of either the plastic used by some
manufacturers, or the thick paper/fibre stuff used between carbs and the manifold?
I need something in the order of 5mm thick.
Anyone know what the materials are called, and / or a supplier?
[Edited on 13/8/10 by r1_pete]
snapper
| posted on 13/8/10 at 12:52 PM |
I think it's called Phenolic, a glass/resin compressed gasket that stops heat to the manifold from the block
I eat to survive
I drink to forget
snapper
| posted on 13/8/10 at 12:55 PM |
Found it
Here
I eat to survive
I drink to forget
coyoteboy
| posted on 13/8/10 at 01:56 PM |
http://www.directplasticsonline.co.uk/PTFESheet/0.5mm/
snapper
| posted on 13/8/10 at 04:41 PM |
You'll want thicker than 1/2 a mill to be effective
5 mm min to 10 mm
I eat to survive
I drink to forget
snapper
5 mm min to 10 mm
I eat to survive
I drink to forget
coyoteboy
| posted on 17/8/10 at 10:36 AM |
It was more the link to the source, rather than the actual product (I just grabbed it from my bookmarks as I've used that on other projects).
