Author: Subject: Megasquirt Zetec Direct Coil Driving with Relay Board Cable?
chrisspartan
posted on 18/8/10 at 10:34 PM Reply With Quote
I am just wiring up my Megasquirt and have installed the Relay Board and cable.
Should the direct coil driver wires (I have 2 coil drivers driving wasted spark zetec, Pin 6 + 36) be routed seperately to the main Relay board cable to avoid induced noise or am I worrying about nothing? If its OK to use main cable can the relay board take the current of the coil drivers through the tracks?
I know I should fit capacitor with the 12v coil feed wire.
Thanks in advance.
Chris
ashg
posted on 19/8/10 at 10:24 AM Reply With Quote
mine are routed together and haven't had a problem. the signal drops low to fire the coil so should be reasonably noise resistant.
