Author: Subject: R6 TB's & Morgan Carbtune II
Bumble
posted on 18/9/10 at 05:54 PM Reply With Quote
Ok, I am trying to balance my R6 TB's fitted to my Zetec. There are 2 weee brass tubes underneath each TB which are simply looped together with vac hose (there's pics in my archive under TB's cunningly).
Which if these do I use to conect up to the Morgan Carbtune to balance the little buggers and is looping them together OK?? What does each of them do? Final question, there's a brass adjuster screw next to them.......what does this little chap adjust?
Probably best if I get a Haynes Manual but thought I'd ask first as others have used these before.
Thanks,
Matt
big_wasa
posted on 18/9/10 at 06:19 PM Reply With Quote
yeh the one that links them is fine. It was used for the map sensor.
Bumble
posted on 18/9/10 at 07:23 PM Reply With Quote
Hi Warren,
They are actually looped now....look at "TB Drawing 1" in my archive......the Red loops show how they are now joined up.
Runs much better when I disconnected them today......hence the questions.
Matt
MakeEverything
posted on 18/9/10 at 10:44 PM Reply With Quote
R6 TB's 1
R6 TB's 1
Kindest Regards,
Richard.
Bumble
posted on 19/9/10 at 08:40 AM Reply With Quote
Richard, thanks but wrong pic. How do you install the pic??
Ta,
Matt
Originally posted by MakeEverything
R6 TB's 1
R6 TB's 1
