oadamo
| posted on 18/9/10 at 07:57 PM |
cheap high flow injectors ?
iam after 800-1000 injectors but i was thinking of modding some standard injectors save me paying 300 quid+ on some,
any ideas on what i can use.
adam
matt_gsxr
| posted on 18/9/10 at 10:23 PM |
In true web forum tradition...
Have you considered multiple injectors. This might sound like a bodgy way of saving money, but actually you get better mixing and charge cooling.
This would change your problem to "how can I get loads of 400-500ml/min injectors". I don't know the answer, but wouldn't be
surprised if subaru/mistubishi evo was the answer.
Matt
MakeEverything
| posted on 18/9/10 at 10:31 PM |
You should be able to increase the size of your injectors by just replacing the existing. I would make sure they have been cleaned first though.
Youll need to know the capacities and part numbers though, in order to be able to identify and select an appropriate replacement.
For example, i have Bosch 802 injectors and a set of 803's as a backup to provide an additional 100cc/min if needed.
Look Here
[Edited on 18-9-10 by MakeEverything]
Kindest Regards,
Richard.
