Paul (Notts)
| posted on 19/9/10 at 06:43 AM |
Megasquirt - fuel pump question
Reached the stage where I have my lap top talking to the Megasquirt and the LC1.
Got readings for air temp, water temp, MAP ect on the display.
As Its a home made injection system I want to turn the high pressure pump on so that I can check the feul lines for leaks.
CanI do this via the ecu settings or Do I neeed to power the pump up on its own to check for leaks.
Paul
scudderfish
| posted on 19/9/10 at 06:58 AM |
I just connected my pump straight to 12v when I wanted to test the HP circuit for leaks. Simplest way of doing it, and you control how long it runs
for, not the ECU so when it goes leak, you can immediately kill it
matt_gsxr
| posted on 19/9/10 at 07:32 AM |
Default MS1 is to turn the pump relay on for 3 seconds when the MS is first turned on.
That should be enough to pressurize the system and show up any leaks. I have found that my ability to detect the smell fuel has improved since I
started making a car!
Matt
MakeEverything
| posted on 19/9/10 at 09:08 AM |
Matt
Or do you mean that you ability to smell fuel and detect leaks is now a habit?
Kindest Regards,
Richard.
Paul (Notts)
| posted on 19/9/10 at 10:45 AM |
Fuel system up and running -no leaks or smells
| posted on 19/9/10 at 10:52 AM |
Start up soon then?
Paul (Notts)
| posted on 19/9/10 at 11:36 AM |
Some more little jobs to do then next Saturday - set up video canera ansd start her up
Paul
