donn006
| posted on 24/9/10 at 08:18 PM |
c20let ecu ,,,vauxhall turbo engine
hi im now going to change my engine from the c20xe red top to the c20let turbo engine. i just need to know if i can use my mbe 956 ecu to run it or
will i need a new ecu. the ecu is running gsxr throttle boddies with tps ,coolant temp and crank pick up sensors
austin man
| posted on 24/9/10 at 08:24 PM |
would have thought the ecu needs to have a MAF sensor input also
laptoprob
| posted on 25/9/10 at 07:14 AM |
Definitely will not run on the 956.You could maintain the tb`s and build a plenum for it, they will save u some room under the hood.I considered it my
self but its quite a job to do apparently.
