Author: Subject: R1 carb fuel leak
matty h
posted on 28/12/10 at 01:30 PM Reply With Quote
R1 carb fuel leak
I have just put R1 carbs on my engine fired it up to find fuel coming out below where the trumpets go on in the two slots anyone know why ??
whitestu
posted on 28/12/10 at 02:40 PM Reply With Quote
Bike carb float valves are prone to leaking if the carbs have been standing for a while as they get dirt in and don't seal. Try cleaning them first.
Stu
matt_gsxr
posted on 28/12/10 at 03:10 PM Reply With Quote
In addition to the above. What pump are you using.
You don't need much pressure.
matty h
posted on 28/12/10 at 07:50 PM Reply With Quote
Got a mg midget pump fitted was thinking it could be pressure problem so I am looking at fitting facet solid state pump which is 2.5-3psi.
matty h
posted on 1/1/11 at 07:32 PM Reply With Quote
Started today and no leaks must of been some dirt.
