thunderace
| posted on 18/1/11 at 02:24 PM |
should fuel come out?
i have a 1990 mk1 golf cabrio for the mrs and its been in the garage for 5 years and not started so i got new cap plugs leads and airfilter ,i want to
drain the fuel from the car as its been in it 5 years ,i removed the banjo from the filter, after trying to take a feed from the return ,i turned the
ignition on and can here a buzz for 2 seconds but no fuel is coming out ?
here is a pic of where there is no fuel coming out.
SeaBass
| posted on 18/1/11 at 02:39 PM |
The old K-Jet has a relay that runs the pump while the engine is firing (coil pulses). It primes the system for a few seconds when the ignition is
switched on prior to cranking.
Yes fuel should come from the output of the filter but I would bypass the relay to test fuel delivery as it can take some seconds when the fuel lines
have fully leaked down. There is a non return on the output of the fuel pump as far as I remember to keep fuel in the lines under normal usage - loads
of info on the web.
Davey D
| posted on 18/1/11 at 03:04 PM |
when i wanted to empty the tank on my VortX i just ran a wire from the +ve terminal of the battery directly to the fuel pump.
matt_gsxr
| posted on 18/1/11 at 10:42 PM |
You could disconnect the pipe on the output of the pump down infront of the rear drivers side wheel.
This pipe rusted through on my Mk1 golf Gti (also k-jet) when I left it in a garage for 3 years. I guess a bit of water collected and it rusted
up.
I miss that car
