Author: Subject: How and where to plumb in fuel pressure regulator?
adrianreeve
posted on 19/3/11 at 03:20 PM Reply With Quote
Hi there,
The Jenveys and manifold I have bought don't have a take-off for vacuum for the fuel pressure regulator. Do I just need to drill and tap the manifold, and if so, where is best? Or can I get away without connecting vacuum port, and just have a constant fuel pressure?
Adrian
will121
posted on 19/3/11 at 03:31 PM Reply With Quote
Vacuum connection to fuel regulator just reduces pressure at tick over for better injection control but can't see it being an issue to map with constant pressure unless injector are bit to big
posted on 19/3/11 at 04:41 PM Reply With Quote
Didn't bother with a vacuum connection on mine , as said mapping should sort it out
adrianreeve
posted on 19/3/11 at 04:48 PM Reply With Quote
Cheers guys
Bare
Sure.. but doesn't effective mapping require significant time an a 'decent' dyno, the fitting of a wideband lambda and an egt device.
Seems to me to be way easier to say than do.
adrianreeve
posted on 19/3/11 at 04:51 PM Reply With Quote
It's going to be mapped anyway, so no problem
