matty h
posted on 3/5/11 at 01:18 PM |
R1 carb fuel pressure
Just purchased a fuel regulator to fit on my car with R1 carbs what fuel pressure do they require.
Thanks in advance Matty
MK9R
posted on 3/5/11 at 01:26 PM |
oops, edited and deleted, thought it was a BEC question about pump for an R1
[Edited on 3/5/11 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
big_wasa
posted on 3/5/11 at 02:42 PM |
2psi is plenty.
matty h
posted on 20/5/11 at 03:06 PM |
Have fitted a pro flow regulator it has 0.5psi increments on checking with a gauge at 2psi it is 2.25psi and at 1.5psi it is 1.75psi currently set it
to 2.25psi should I drop the pressure down some more.
