Cordite69
| posted on 7/5/11 at 06:50 AM |
Fuel pump
Can anybody suggest what fuel pump I should use with my 2001 blackbird engine? Will any external fuel injection pump work?
spiderman01980
| posted on 7/5/11 at 07:13 AM |
i bought a facet fuel pump off ebay and then a pressure regulator to go on my gpz900, or try contacting honda and asking what they would reccomend as
a replacement pump.
Cordite69
| posted on 7/5/11 at 07:48 AM |
Thanks. I think the fuel rail has a regulator built onto it so it's just the pump.
What type of facet pump did you use? Honda just tell me to use the original pump from the bike tank but I already have a fuel tank and don't
fancy cutting a hole in the bottom of it.
I had a look under a couple of cars at Stoneleigh show with bike pump under tank and the seemed dangerously close to the floor!!!!!
spiderman01980
| posted on 7/5/11 at 08:00 AM |
i bought one like this FACET LOW PRESSURE CARB ELECTRIC FUEL PUMP 150BHP | eBay UK .
| posted on 7/5/11 at 08:04 AM |
Think you might struggle to get the engine running on that pump due to it being a LOW PRESSURE CARB pump NOT injection?
spiderman01980
| posted on 7/5/11 at 08:06 AM |
the engine i have is not injection, the first gpz never had a pump.
| posted on 7/5/11 at 08:20 AM |
Clue?
spiderman01980
| posted on 7/5/11 at 08:24 AM |
he asked me which one i bought, i only reccomended to use a facet pump which come in different pressures, what pump would you reccomend he should use?
adithorp
| posted on 7/5/11 at 08:32 AM |
Seemed pretty clear he asked initially about a pump for injection. T be fair your second post didn't mention carbs so unless youknow Facet pumps
are for carbs it's fair to assume you were refering to inj to answer the initial Q.
Any tin-top external pump will do. They all provide roughly the same prssure but some have greater flow rates than others and the
inlet/outlets/terminals differ. I'm running one from an Escort RS Turbo (bosch 0 580 464 070).
http://jpsc.org.uk/forum/
spiderman01980
| posted on 7/5/11 at 08:41 AM |
You learn a new thing every day!!
spiderman01980
| posted on 7/5/11 at 09:00 AM |
adithorp would you say i`d need to use a pressure regulator running this pump on bike carbs?
| posted on 7/5/11 at 09:23 AM |
Bike carbs would need the lowest pressure Facet Solid state pump.
Link Facet Pump Catalogue
adithorp
| posted on 7/5/11 at 09:33 AM |
My post with the referance to "tin-top pump" is with regard to the OP's question, assuming he has Fi. I don'tknow if presure
reg would cope with a high presure pump, as Fi pumps put out circa 3bar. You'd be better off to use a low presure pump (like a facet) of the
correct presure, or a low presure pump and regulator. EAOE
spiderman01980
| posted on 7/5/11 at 09:58 AM |
Sorry mate I ment with the pump i already have which is a facet, i got to learn to make things clear when i type lol.
adithorp
| posted on 7/5/11 at 10:52 AM |
You'd need to check the tech' manual for the carbs and then compare with the pump, but chances are you'd need a reg'.
Cordite69
| posted on 7/5/11 at 01:47 PM |
Sorry, I didn't mention it is a fuel injected engine!! My fault!! I was going to try the rs turbo pump because it seemed the most straight
forward to fit?
