AndyG
| posted on 11/5/11 at 07:01 PM |
Help Identifying Fuel Hose Connectors
I'm in the process of installing my throttle bodies and I am trying to update the fuel lines however where the orginal lines
enter the engine bay to go to the old fuel rail is a screw on fitting of approx 16mm does anyone know of a fitting that i can
use to convert them to a push on fitting as I'm struggling to find something that will fit as the hose for the fuel rail is only 8mm.
mcerd1
| posted on 11/5/11 at 07:08 PM |
  Fuel Connectors 1
  Fuel Connectors 2
oadamo
| posted on 11/5/11 at 07:10 PM |
they look like jic hose fitting.
adam
if you need a diff size fitting to screw onto them, see if you can unscrew yours to see what size tread is on them as i have a bag full with diff size
treads on each end.
adam
[Edited on 11/5/11 by oadamo]
AndyG
| posted on 12/5/11 at 01:07 PM |
Thanks for your reply I will check the size tonight and let you know.
